Hermans182
#1 Posted : Wednesday, December 22, 2010 8:37:31 AM(UTC)
Hermans182
The door won't close all the way, so the light stays on. I replaced the hinge/spring assy but I still have the problem. I can't find a way to adjust the spring tension.Does anybody have an idee?
michaela
#2 Posted : Wednesday, December 22, 2010 9:20:14 AM(UTC)
michaela
I had a problem with my door and replaced the hinge. There was still a problem. In my case the hinge was hitting the trim/base board.
This was keeping the door from shutting all the way.
So check the hinge an make sure it has enough clearance to function.
Oven door problem (Oven Repair (including Ranges and Cooktops))
by TugCap 4/23/2016 12:48:34 PM(UTC)
Magic Chef Oven Door Problem (Oven Repair (including Ranges and Cooktops))
by chefkingoven 8/21/2012 5:48:14 PM(UTC)
by G. Wedlake 3/30/2009 9:26:46 AM(UTC)
The Dreaded Oven Door Problem! (Dishwasher Repair)
by Heymate 1/20/2009 10:16:24 PM(UTC)
Tappan Wall Oven Door Problem (Oven Repair (including Ranges and Cooktops))
by florenceshield 1/9/2009 6:35:19 PM(UTC)
by Larry Golden 11/5/2008 12:59:34 PM(UTC)
oven door problems (Oven Repair (including Ranges and Cooktops))
by chopperbobby 11/3/2008 1:34:14 PM(UTC)
oven door problem (Oven Repair (including Ranges and Cooktops))
by lee-lester 9/21/2008 8:58:00 PM(UTC)
by lee-lester 9/21/2008 6:03:28 PM(UTC)
