2 Pages12>
craigjr
#1 Posted : Wednesday, August 27, 2008 3:58:45 AM(UTC)
craigjr
my maytag works on all cycles but the inner drum in now locked up and will not spin by hand.my guess is the tranny is bad. im not a tech this is why im posting.
libertyappl
#2 Posted : Wednesday, August 27, 2008 4:56:39 AM(UTC)
libertyappl
It could be that the brake is locked up.
craigjr
#3 Posted : Wednesday, August 27, 2008 5:54:34 AM(UTC)
craigjr
how do i repair this problem. is it in the trans part.
libertyappl
#4 Posted : Wednesday, August 27, 2008 6:04:59 AM(UTC)
libertyappl
Yes it's in the transmission area. If you look at the breakdown- part 21,22 & 23. #23 is probably rather rusty which can cause the whole thing to "lock" up.
But you probably should inspect all the parts in that area.....to for warn you they are a pain in the rear ( just our opinion)
craigjr
#5 Posted : Wednesday, August 27, 2008 6:19:21 AM(UTC)
craigjr
i have the tranny out and removed the brake and dont see nothing visible. spring looks ok . the drum was spinning at one time and as it spins it would stop and start back up again and spin. when she was done all the wash it was locked up and i couldnt spin the drum by hand.i just want to be as specific as i can. what is there visibly to see on the brake that causes it to go bad. also i inspected the brake and drum and the drum is shiny on half the drum. like it was eather cocked to one side and braking on half the drum. the brake look fine they dont look worn at all.
libertyappl
#6 Posted : Wednesday, August 27, 2008 9:02:37 AM(UTC)
libertyappl
There is cam type part that raises the drum to spin that part maybe bad.
craigjr
#7 Posted : Wednesday, August 27, 2008 2:16:23 PM(UTC)
craigjr
i checked the cam and dont see no visible wear. i put it back together and the brakes are not locked up like it was before. there is a minimum drag on the brake.when you turn the cam manually it releases the brake and there is no drag. do you think the cam can be worn.
libertyappl
#8 Posted : Wednesday, August 27, 2008 5:31:21 PM(UTC)
libertyappl
It's very possible, try it for a load or two and see how it does. Then if nessessary try changing the part.
craigjr
#9 Posted : Friday, August 29, 2008 9:12:54 AM(UTC)
craigjr
well i put back together and now i can spin the drum by hand but when i plug it in the agitator works but drum does not spin. when i put the pulley back together w cam i had to pry down the brake drum to install it with the clip. is this what you are supposed to do. can you send me a pic of the center pulley so i can see how the cam is installed. im sure it is correct but not certain. thanks for all the help
libertyappl
#10 Posted : Friday, August 29, 2008 10:53:00 AM(UTC)
libertyappl
This is how I look at most machines.
libertyappl attached the following image(s):
Guest (6)
Washer Drum will not spin (Washer Repair)
by DoSchultz 7/21/2011 12:31:02 PM(UTC)
washer drum will not spin (Washer Repair)
by hlsjmc1 3/12/2010 4:32:50 PM(UTC)
2 Pages12>
