AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Whirlpool Gas Dryer Runs, Start Heating then gas heat goes off - stays off...
Got the part, replaced coils and all works great now. Thanks Gene!!
You're welcome. We're glad you were able to fix it.
Originally Posted by: libertyappl  The coils are on top of the regulator. You can see them on the break down of your dryer. Hope that helps. Gene was more help than I was. Glad he jumped in! Nat I have the same problem as DRS. Model #LG5801XKW0 Whirlpool Where is the coil? Or what else could it be? Thanks
Newguy, Your coils are a little different that DRS' but if you can pull up the breakdwon of your machine they are #32 on trhe burners page. Nat
I have the same problem but when I loosened the limiter, part 15 ( Model SGDS800HQ0, ) the burner lit everytime. When it was tight it would fail to light. Anyone know what this brass screw/cap actually does? thanks
evanv, Sounds like the problem with your dryer is a bad gas valve. - The part number for the gas valve assembly is AP3094298 Gene.
Dryer Repair
