Reddy33L
#1 Posted : Saturday, August 16, 2008 11:50:02 AM(UTC)
Reddy33L
Hi, my top load Kenmore Elite 111 is leaking water and it appears to be coming from the upper right corner. I think this is during the spin cycle. is there a gasket or something like that in that area that could be bad? I cant lift the lid to look while its running. Thanks for your input.
libertyappl
#2 Posted : Saturday, August 16, 2008 12:07:20 PM(UTC)
libertyappl
Can you locate the full model number? should be about 11 numbers total.
Nat
#3 Posted : Sunday, August 17, 2008 10:57:25 AM(UTC)
Remove the outer cover and check for a leaking water pump.
Reddy33L
#4 Posted : Wednesday, August 20, 2008 10:00:05 PM(UTC)
Reddy33L
I found the problem in the bleach reservoir located at the front right corner top. The drain was plugged and reservoir overflowed and ran onto the floor. Thanks for your input
libertyappl
#5 Posted : Thursday, August 21, 2008 8:15:43 AM(UTC)
libertyappl
That's what i was going to suggest by your description a full model number helps when looking at breazdowns of these machines.
Nat
