twilliams0204
#1 Posted : Thursday, December 16, 2010 6:26:06 PM(UTC)
twilliams0204
We own a Maytag MDE9706AYW dryer that has been great. It recently stopped turning off on its own. The timer does not seem to advance. I purchased and replaced the timer module on it but got the same result. We ran it while not attached to the vent as we read to try that in some forums. The heat works fine. The moisture sensor may not be working either and I'm curious if that could be related. I did notice that the bell never "dings" now either even when manually turning off with the dial.
Any help you can provide would be great.
#2 Posted : Friday, December 17, 2010 1:30:01 AM(UTC)
Here is your parts breakdown it includes a wiring layout
http://www.appliancepartspros.c...ch.aspx?model=MDE9706AYW
Here is the link to a MDE7600.
I include this as it has an actual wiring diagram and I believe yours is very close to this one.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47870&diagram_id=28472256#d28472256
On these dryers the timer motor gets power from the moisture sensor (electronic control) board.
So if it the timer does not advance in timed dry and auto modes than this board is probably shot.
For the life of me I cannot find the board in the parts.
kayakcrzy
#3 Posted : Friday, December 17, 2010 3:37:48 AM(UTC)
kayakcrzy
Sometimes, one of the wires vibrates off of the sensor. I went out on a service call the other day and found that to be the problem. Tom ApplianceEducator.com
