2 Pages12>
cmize
#1 Posted : 14 years ago
cmize
This thing just stopped working. Its has the in door ice n water dispencer. It is not making any ice. When you push the despenser for ice in it just kind hums as though it wants to drop ice but there is none. I am clueless about all this. thanks
magician59
#2 Posted : 14 years ago
magician59
What's the temperature inside the freezer?
cmize
#3 Posted : 14 years ago
cmize
Not sure, I can get something to check it with n get back to you. The settings are A B n C. A being the warmest C the coldest. It is set on A and everything is frozen like I assume it should be.
magician59
#4 Posted : 14 years ago
magician59
Are there ice cubes in the ice bin?
cmize
#5 Posted : 14 years ago
cmize
no its not making anything
ApplianceJunk
#6 Posted : 14 years ago
ApplianceJunk
The water fill tube to the ice maker could have frozen shut.
Ice Maker Repair Service Manuals - ApplianceDigest.com
cmize
#7 Posted : 14 years ago
cmize
I checked a white hose that goes up back of refrigerator. I guess its to ice maker or it could go to ice maker, what ever it goes to its fine n not frozen. The water in the door does work if that matters. Is there any trouble shooting for dummies that I could do?
ApplianceJunk
#8 Posted : 14 years ago
ApplianceJunk
The water going to the door is not the same water line that goes to the ice maker.
You say you checked the line going to the ice maker, yet you sound unsure of what it is you even checked.
You would need to remove the water line that runs to the ice maker and blow air through it to make sure it's not frozen shut.
cmize
#9 Posted : 14 years ago
cmize
would this line run up the back exposed?
cmize
#10 Posted : 14 years ago
cmize
ok i got it. The line is not frozen. What about that thing under the fridge that that line hooks into or the arm that that trips the relay when the ice bin is full?
Whirlpool Icemaker Not Working (Refrigerator & Freezer Repair)
by dtnel 13 years ago
Whirlpool icemaker not working (Refrigerator & Freezer Repair)
by jsquail 14 years ago
by jc1506 15 years ago
Whirlpool Icemaker not working (Refrigerator & Freezer Repair)
by Chuck Tomney 16 years ago
by jparte01 17 years ago
2 Pages12>
