kenbary
#1 Posted : Wednesday, December 15, 2010 3:28:40 PM(UTC)
kenbary
My front loader washer drum hangs up now and then. I can force it to turn and feel something move free maybe a sock or something got through the seal and is on the outer side of the drum getting caught. It will happen again and again after I turn it mannualy and then run it. Where do I begin to open the unit. Front Back Top etc.
Any help would be appreaciated
kenbary@comcast.net
#2 Posted : Thursday, December 16, 2010 1:38:56 AM(UTC)
You will need to remove the tub to pump drain hose to fish out any stuck item. You might find the wire clamp imposable to get back on, so you will need to buy a adjustable clamp to replace it.
kenbary
#3 Posted : Thursday, December 16, 2010 3:59:38 AM(UTC)
kenbary
Do you know what section to remove first? Back or front or top???
I never openend this one before.
#4 Posted : Friday, December 17, 2010 12:20:36 AM(UTC)
You remove the torque screws under the bottom front kick panel, then remove panel.
kenbary
#5 Posted : Friday, December 17, 2010 3:56:59 AM(UTC)
kenbary
Thanks, I will have to wait till Saturday to give it a try
I know these things take more time than you expect.
#6 Posted : Friday, December 17, 2010 5:01:03 AM(UTC)
I forgot, all Frigidaire front loaders have a access panel in the back. Warning!!, Before reaching in, use duck tape on the very sharp edges back there, will save cuts and prevent foul language around Christmas!
kenbary
#7 Posted : Sunday, December 19, 2010 8:34:34 AM(UTC)
kenbary
trying to open the frigidaire front loader to look for stuck item
The back pannel doesnt give me access to see between inner basket and drum.
Should I try front pannel?
#8 Posted : Sunday, December 19, 2010 8:38:02 AM(UTC)
You can't gain access to the inside of the tub, all you can do is remove the drain hose and fish out anything there
kenbary
#9 Posted : Sunday, December 19, 2010 9:30:25 AM(UTC)
kenbary
I think I got it. Before I opened it I ran a dry spin and heard a good couple of thumps. Shut it down and opened it. Got the drain clamp off and drain hose. A sock made its way to the drain. I was right there, I just plucked it out and put drain hose clamp back on. doing a test wash right now.
Thanks for your help.
