Firedancer -
I didn't have a problem with the pump, so can't help there. But the top leak sounds like what I faced. I removed the front panel and the top to get access to the tub. Then I removed the splash guard from the tub. I stripped out the old gasket, cleaned it up, and replaced the gasket with a bead of slilicone caulk. I put her back together, and she seems to work fine.
Chris
Wow - excellent! I'll give that a shot. Thank you!
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hi, can I repair a tub seal with my dryer still stacked on top? I hate to have to remove it and then put it back. I don't have space right now to put them side by side.
Rank: Guest
Why my fridgedair washer top load leaks when filling up and washing not when draining.
