Hi!
My Whirlpool side by side refrigerator, model # ED2JHGXRQ00 is not defrosting.
I don’t see a defrost timer in the parts breakdown list but the parts list shows a “bi-metal defrost”. Is this the same thing? I ohmed out the heater coil at 26 ohms. Any ideas?
Thanks, Joe
Joe, your model has an electronic control. It's either the control or the defrost bi-metal nat
Hi Nat,
Is there a way for me to determine whether it is the bi-metal or the controller?
Thanks, Joe
The easiest way is to test the bi-metal for continuity, if it tests ok then it's probably the control. Hope that helps Nat
