dhamrick
#1 Posted : Monday, December 13, 2010 9:25:17 AM(UTC)
dhamrick
I ordered the ERC part (part # AP3205899) from your company today; however, the representative was not sure that the installation/replacement instructions would be included with the part. I am certainly not a repair expert; however, I can usually follow instructions well. The display indicates a F7 error code with a "56" flashing code to the right. It is my understanding that replacing the ERC will correct this, but I would like to review the instructions prior to receiving the part. Please advise if you can provide step-by-step instructions. Thanks so much!
#2 Posted : Monday, December 13, 2010 4:11:04 PM(UTC)
The "F7" error code means that control senses shorted Start key.
The problem can be a bad key panel as well as a bad ERC or EOC ( two names for the same part - electronic control).
Based on my experience a faulty key panel is much more possible. So I would replace the key panel first. The instructions are attached to the reply.
- The key panel Part number: AP4411791
dhamrick
#3 Posted : Tuesday, December 14, 2010 9:29:37 AM(UTC)
dhamrick
Thanks for your prompt response; however, I already ordered the ERC (part # AP3205899) and it has been shipped. The representative with your company advised this was the correct part. Should I now order the part you suggested in your response (AP4411791)? Thanks again!
#4 Posted : Tuesday, December 14, 2010 2:04:28 PM(UTC)
The part number for the ERC is correct but I'm not sure if it will fix the problem.
dhamrick
#5 Posted : Tuesday, December 14, 2010 4:23:53 PM(UTC)
dhamrick
Ok-this is my last question. Should I order the other part (the panel) prior to installing (or attempting to install) the ERC? I apologize for all the questions-just took the advice of 2 different reps with your company that the ERC was the part I needed-which costs more than the panel. I would like to minimize my costs but obviously want the problem corrected. Thanks again for your patience and assistance!
dhamrick
#6 Posted : Wednesday, December 15, 2010 7:09:12 AM(UTC)
dhamrick
After reviewing all of the information you provided, you clearly provided your advice in your first response; therefore, I ordered the part you suggested today. If I find that we do not need the ERC part, we will return. Thanks again for your assistance-you have been GREAT to work with!
#7 Posted : Wednesday, December 15, 2010 1:13:45 PM(UTC)
You are welcome. Thank you for your good words and good luck with your oven. Keep us posted.
