jerman
#1 Posted : Tuesday, September 25, 2007 9:24:44 PM(UTC)
jerman
maytag washer serial number 16846195ax : problem water does fill the washer on the timer fill cycle.Replaced water valve hot / cold.Had no effect on washer.Checked voltage across hot and cold solenoid valve.Could not detect voltage at solenoid valve unless using washer body used as ground.Detected approximately 100-108 volts at the hot and cold water solenoid valve.No ground at solenoid valve that i could see.It appears the neutral side is not completing the circuit when testing across the solenoid connectors ie no voltage reading.
Noticed the washer pumps out on the final rinse cycle and the agitator is working on that cycle.Otherwise no water filling the tub on the first cycle.
#2 Posted : Thursday, September 27, 2007 1:29:26 AM(UTC)
Washer power ground is daisy chained at different connectors, you will need to continuity test with an ohm meter from wall socket plug to water solenoid to find the problem.
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
