2 Pages12>
mrblonde108
#1 Posted : Sunday, August 24, 2008 6:53:17 PM(UTC)
mrblonde108
Hi all. It a Frigidaire frt12crh HWO.
Anyway it has condensor on back with no fan.air cooled.
I pulled evaporator cover and fan isn't working. I let it on for over 24 hours and evaporator wasn't really getting cold. But the heatexhanger was building up frost quickly. After 24 hours it had a good build up of ice.
The fan not working wouldn't cause this, would it?? Also can some one explain what the heat exhanger does? Is refrigerator junk??
Thank You
libertyappl
#2 Posted : Sunday, August 24, 2008 6:59:31 PM(UTC)
libertyappl
If it's less than a year old, I would put everything back the way it was a call a certified tech. Let Frigidaire repair it
Nat
mrblonde108
#3 Posted : Sunday, August 24, 2008 7:05:30 PM(UTC)
mrblonde108
It worked fine for about a month. When i say heat exhanger i mean the thing next to the evaporator with a thin copper tube running into a bladder that looks like a Co2 tank. That's what is freezing up. the fridge is at least 5 years old.
libertyappl
#4 Posted : Sunday, August 24, 2008 7:28:54 PM(UTC)
libertyappl
The heat exchanger cools the liquid going into the capillary tube.
Look near the compressor and see if there is a tapon on one of the coper tubes. It just a little attachement for freon.
libertyappl
#5 Posted : Sunday, August 24, 2008 7:32:19 PM(UTC)
libertyappl
could you double check the model number it doesn't pull up on a breakdown
Nat
mrblonde108
#6 Posted : Sunday, August 24, 2008 7:35:56 PM(UTC)
mrblonde108
Ok. I will check tomorrow. I think i looked already but didn't see anything. Here is the parts illustration of the fridge. The frozen thing i'm referring to is #13 on the System illustration.
libertyappl
#7 Posted : Sunday, August 24, 2008 7:41:05 PM(UTC)
libertyappl
The model number you have posted here doesn't pull up can you repost it.
Nat
mrblonde108
#8 Posted : Sunday, August 24, 2008 7:41:07 PM(UTC)
mrblonde108
Model is frt13crhwo
http://www.frigidaire.com/suppo...rModel=frt13crh&User=[URL="ftp://ftp.electrolux"][/URL]
mrblonde108
#9 Posted : Sunday, August 24, 2008 7:48:06 PM(UTC)
mrblonde108
[FONT='Times New Roman']ftp://ftp.electrolux-na.com/ProdInfo_PDF/Anderson/95322046.pdf[/FONT]
libertyappl
#10 Posted : Sunday, August 24, 2008 7:55:26 PM(UTC)
libertyappl
Do you have a frost pattern on the whole evaporator coil?
2 Pages12>
