Gerald Sr
#1 Posted : Sunday, August 24, 2008 6:01:07 PM(UTC)
Gerald Sr
ignitor on the right front will not lite, the other three burners work ok
Gerald Sr
#2 Posted : Sunday, August 24, 2008 6:07:11 PM(UTC)
Gerald Sr
ignitor on right front will not lite, the other three work ok
libertyappl
#3 Posted : Sunday, August 24, 2008 6:37:38 PM(UTC)
libertyappl
Can you double check your model number there should be 11 number. Helps us help you.
Nat
Kenmore gas oven will not stay at temperature (Oven Repair (including Ranges and Cooktops))
by kosgood 2/13/2021 8:51:55 AM(UTC)
Kenmore gas oven lights but won't get hot (Oven Repair (including Ranges and Cooktops))
by BonnieLC 5/14/2017 5:42:25 PM(UTC)
Kenmore gas oven won't heat up properly (Oven Repair (including Ranges and Cooktops))
by Black Cherry 3/27/2013 11:12:55 AM(UTC)
Kenmore Gas Oven Not cooking evening (Oven Repair (including Ranges and Cooktops))
by ghauptman 12/23/2012 6:47:06 AM(UTC)
Kenmore gas oven not lighting (Oven Repair (including Ranges and Cooktops))
by wingmaster12 11/11/2012 11:11:11 AM(UTC)
Kenmore Gas Oven works only sometimes (Oven Repair (including Ranges and Cooktops))
by Sixmenn 6/21/2010 4:48:50 AM(UTC)
Replacing round igniter on Kenmore gas oven (Oven Repair (including Ranges and Cooktops))
by techmonster 4/24/2010 11:55:57 AM(UTC)
by lexicarl 4/22/2010 9:59:23 AM(UTC)
Kenmore Gas Oven Control Panel replacement (Oven Repair (including Ranges and Cooktops))
by j.clayton 2/12/2010 12:35:45 PM(UTC)
by j.clayton 2/12/2010 12:34:17 PM(UTC)
Kenmore Gas oven burner too high ?!? (Oven Repair (including Ranges and Cooktops))
by 350rocket 10/24/2009 2:33:23 PM(UTC)
Kenmore gas oven doesn't ignite (Oven Repair (including Ranges and Cooktops))
by Jigger 8/24/2009 7:56:24 AM(UTC)
Kenmore gas oven will not turn ON (Oven Repair (including Ranges and Cooktops))
by skidoomxz99 8/20/2009 3:42:25 PM(UTC)
Broken Kenmore Gas oven (Oven Repair (including Ranges and Cooktops))
by jlraatz 3/18/2009 2:33:10 PM(UTC)
Kenmore gas oven display reads 'door' (Oven Repair (including Ranges and Cooktops))
by HandyAndy 3/5/2009 10:08:26 AM(UTC)
