My Kenmore gas oven turned on in the off position. Now, when I need to use the oven, I have to turn it on & off several times until I see the flame glow. Once on, the temp can't be controlled. This leaves me to unplug the oven after each use. Any suggestions on the faulty part?
Originally Posted by: lexicarl  My Kenmore gas oven turned on in the off position. Now, when I need to use the oven, I have to turn it on & off several times until I see the flame glow. Once on, the temp can't be controlled. This leaves me to unplug the oven after each use. Any suggestions on the faulty part? What you need a new thermostat. The part # is WB20K8 The thermostat controls the oven. Tom ApplianceEducator.com - Parts
