topfreeze
#1 Posted : Friday, December 10, 2010 1:30:05 PM(UTC)
topfreeze
I have a KitchenAid SS refrigerator, model KSRB25FKSS00.
The thermostats have three prongs with wires attached to them, not counting the ground.
Which prongs do I measure the resistance readings as the cold setting is adjusted?
Do I need to pull the thermostats out, or can they be tested as is with the refrigerator running?
Here's a picture with two prongs on top with third pointing toward viewer:
How to remove the washer cabinet.doc (21kb) downloaded 14 time(s).
topfreeze attached the following image(s):
#2 Posted : Saturday, December 11, 2010 4:26:39 AM(UTC)
Have you looked under the unit (compressor compartment) , behind the kick plate and the rear cover to see if the wiring diagram is tucked/taped there.
What is the problem/symptoms of the unit.
Thermostat can often be checked with a meter using ohms.
Trouble is that if they are intermittent just a slight nudge can close/open contacts that are sticking.
Also getting to the sensing bulb so you can heat it up and cool it down can be a pain.
