nfg kenmore
#1 Posted : Thursday, December 9, 2010 3:01:31 PM(UTC)
nfg kenmore
I had sears $75 tech tell me the control panel was no good along with a circuit board replaced them both, the thermal fuse is in good working order.the dryer is still not working.a "click" from the left upper side is all i get.I'm told to check the broken belt switch How do I check this switch before spending more $$$$$ help!
#2 Posted : Friday, December 10, 2010 1:02:53 AM(UTC)
Replacement parts for KENMORE 11085872401 by Kenmore Elite | AppliancePartsPros.com
I beleive your unit is a close match to the following.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/cdce3c10dcb5382285256aa20064beaa/$FILE/Duetdry.pdf
I am assuming that everything looks normal (interior light, control panel etc.) but it just will not start.
You could open up the unit and check it with a meter, see page 4-9 in the manual.
Who knows you may just have a broken belt.
OR
You could unplug the unit, disconnect P1 from the board and then with the door open measure across the plug from P1-4 to P1-3 for continuity.
This will check the thermal fuse, the belt switch and the motor windings.
If this is infinite ohms (open) then you can dig further.
I would definitely complain about the service you received as it sounds like the service persons poor skills have cost you a lot of money.
Kenmore dryer not working (Dryer Repair)
by JuanY 5/21/2013 8:57:38 AM(UTC)
kenmore dryer not working (Dryer Repair)
by alfee 2/7/2009 3:14:29 PM(UTC)
