alfee
#1 Posted : Saturday, February 7, 2009 3:14:29 PM(UTC)
alfee
hello my names is alfee i have a dryer that turns on and everything but doesnt heat up at all? can i fix it because times are hard now thanks.
#2 Posted : Saturday, February 7, 2009 9:13:08 PM(UTC)
The model number you posted does not look like a valid model number. Verify and repost it.
kayakcrzy
#3 Posted : Monday, February 9, 2009 3:47:47 AM(UTC)
kayakcrzy
The first thing you want to do is check the power coming to the dryer, where the plug goes into the dryer. If you have 240 volts, the next thing to do is unplug the dryer, and ohm out the element. If it is good, it could be a thermal fuse, that would be mounted on the element assembly. This is some general info, because you did not post your model #. Tom ApplianceEducator.com
Kenmore dryer not working (Dryer Repair)
by JuanY 5/21/2013 8:57:38 AM(UTC)
kenmore dryer not working (Dryer Repair)
by nfg kenmore 12/9/2010 3:01:31 PM(UTC)
