Hi All,
We are new home owners (about 2 months). Prior to this issue, it seemed to run very loudly (we assumed it was just normal), but yesterday we went to run it and after filling, it just made a buzzing or humming noise. The draining also works properly. Any ideas? Any other info you need, just let me know.
TIA!
Tia,
Remove the toe panel and inspect the motor for a water marks. Post the result.
The model number you posted is incomplete. Verify and repost it please.
WHich one is the toe panel?
Also, the model number is DU1055XTSS2
