This unit was moved ( rolled )to replace the kitchen floor. Unit was just unpluged when rolling to new spot 5' away. 1 week later ( no problems in new location ) unit was rolled back. Spent some time vacuming under unit ( tumble weeds) Unit's ice maching made ice no problem. First sighn of problem ICE CREAM soft!! tried to turn to colder setting. Freezer side is all clean now , every thing melted!!:eek: So what gives??? Sean
Gene We went into the refrig side and turned the unit to the off position. No way to do this to the freezer side. The comprossure shut down, we kept it off for a couple of minutes. Turned it back on and it seams to be blowing colder air? The fan down below the freezer is blowing like a sunof a gun! Sean
So now the unit both fridge and freezer seams to be on the fritze. Under the freezer in front the air coming out is cold. The fan seams to be the only thing going I think.:mad: Sean
Don't do anything. Let it run for about 24 hours and check the temperature in both compartments.
Gene Both fans are working. The one in the freezer behind the panel. The one under neath aiming @ the small tank. There is a clicking noise and the tank hums a little the clicks and all is quiet. This cycles. Will let it run for a while. Thanks Sean
Originally Posted by: Sean McGillicuddy  Gene Both fans are working. The one in the freezer behind the panel. The one under neath aiming @ the small tank. There is a clicking noise and the tank hums a little the clicks and all is quiet. This cycles. Will let it run for a while. Thanks Sean I have the exact same issue and was wondering if a cause was determined? Compressor? Thermostat? It just suddenly started going through this 5 minute cycle of humming, click, nothing, repeat. No longer cold just that cycle.
Originally Posted by: dankumm  I have the exact same issue and was wondering if a cause was determined? Compressor? Thermostat? It just suddenly started going through this 5 minute cycle of humming, click, nothing, repeat. No longer cold just that cycle. Did you move the unit or unplugg it for a short time?:confused: :confused: We had unplugged it to move it 5' then nothing. We unpluged the unit for 24 hrs to let every thing settle. Plugged it back in and all has been working great! Hope this helps!
It was moved but was still plugged in. It also did not start doing this right after we moved it so the issue seems isolated from moving it. I'm hoping Gene can chime in again and help you and I figure out how to solve.
Originally Posted by: dankumm  It was moved but was still plugged in. It also did not start doing this right after we moved it so the issue seems isolated from moving it. I'm hoping Gene can chime in again and help you and I figure out how to solve. Answered here: http://forum.appliancepartspros...-working.html#post314309Gene.
