avery208
#1 Posted : Monday, December 6, 2010 11:02:19 AM(UTC)
avery208
Washer only spins in Stainmaster mode of Regular cycle, not in other cycles, but timer continues to rotate to usual time to off. Was occ. spinning when manually set to spin on other cycles but no more. Could this be a lid switch problem, a timer problem, or another electrical contact problem? No other problems noted.
:confused:
#2 Posted : Monday, December 6, 2010 12:43:27 PM(UTC)
Originally Posted by: avery208 Go to Quoted Post
...Could this be a lid switch problem, a timer problem, or another electrical contact problem?...
Yes, it could. You have to have an ohmmeter to perform the troubleshooting.
Here are the breakdown diagrams and Replacement parts for NORGE LWM205W WASHER-TOP LOADING | AppliancePartsPros.com
avery208
#3 Posted : Tuesday, December 7, 2010 9:41:13 PM(UTC)
avery208
Thanks, Gene. Is there somewhere I can get this cheaply or borrow one? Is there a different one for appliances?
Overall, do you have an hunch on which is most likely to be the cause?
#4 Posted : Wednesday, December 8, 2010 4:47:05 PM(UTC)
Very likely the problem is a bad timer. You may want to order one from Appliance Parts Pros and give it a try. If it would not fix the problem, you can return it even if the timer was installed.
- The timer Part number: AP4045089
washing machine repair (Washer Repair)
by jeffsdad 1/4/2016 2:56:40 PM(UTC)
by jeffsdad 1/4/2016 2:49:43 PM(UTC)
by robert joyner 3/29/2014 11:23:44 AM(UTC)
by robert joyner 3/29/2014 11:23:41 AM(UTC)
by maindrain 5/8/2012 9:29:13 AM(UTC)
Washing Machine Repair (Washer Repair)
by CAC 1/5/2011 9:48:17 AM(UTC)
by sbell63@rr 10/1/2010 4:53:04 PM(UTC)
whirlpool washing machine repair (Washer Repair)
by igtaylor3@msn.com 7/21/2009 6:39:44 AM(UTC)
Washing machine repaired (Washer Repair)
by noi 7/6/2009 3:03:53 PM(UTC)
Washing Machine repair (Washer Repair)
by dqf 9/24/2008 5:29:18 AM(UTC)
