AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer cuts off then will turn back on after cooled off
Dryer cuts off after 10-15 minutes. I can open the door and let it cool off for 10-15 minutes and it will cut back on. Any help with this?
Do you have a wrinkle prevent mode. Our dryer has a wrinkle guard setting, which restarts the dryer every few minutes to keep the stuff from wrinkling. Check this...otherwise I don't know.
Originally Posted by: hollywilhite  Dryer cuts off after 10-15 minutes. I can open the door and let it cool off for 10-15 minutes and it will cut back on. Any help with this? Sounds like the motor has gone bad due to overheating. Most likely it's blocked with the lint accumulated on and around the motor. - The motor Part number: AP3094233
Dryer Repair
