Francisco Dan
#1 Posted : Tuesday, December 7, 2010 12:46:57 PM(UTC)
Francisco Dan
:mad: Oven stops heating. I was using the oven at 200 degrees. After about 2 hours it stopped heating. I turned it off and then back on at a higher temperature, 350 degrees. I would not turn on. The top burners and clock all work. What should I DO?
angmf2233
#2 Posted : Tuesday, December 7, 2010 12:53:15 PM(UTC)
angmf2233
Get your crock pot out, thats what I am doing for now! Sucks close to holiday and can't make cookies! Goodluck! I got same problem-no working oven.
#3 Posted : Tuesday, December 7, 2010 3:05:18 PM(UTC)
Most likely the problem is a bad oven igniter. You have to remove the oven floor and the flame spreader to access the part.
- The oven igniter Part number: AP4012072
#4 Posted : Tuesday, December 7, 2010 3:06:32 PM(UTC)
What is the complete model number of the oven?
