:mad: Oven stops heating. I was using the oven at 200 degrees. After about 2 hours it stopped heating. I turned it off and then back on at a higher temperature, 350 degrees. I would not turn on. The top burners and clock all work. What should I DO?
Get your crock pot out, thats what I am doing for now! Sucks close to holiday and can't make cookies! Goodluck! I got same problem-no working oven.
Originally Posted by: Francisco Dan :mad: Oven stops heating. I was using the oven at 200 degrees. After about 2 hours it stopped heating. I turned it off and then back on at a higher temperature, 350 degrees. I would not turn on. The top burners and clock all work. What should I DO? Most likely the problem is a bad oven igniter. You have to remove the oven floor and the flame spreader to access the part. - The oven igniter Part number: AP4012072
Originally Posted by: angmf2233 Get your crock pot out, thats what I am doing for now! Sucks close to holiday and can't make cookies! Goodluck! I got same problem-no working oven. What is the complete model number of the oven? Gene.
