Susan T
#1 Posted : Wednesday, August 20, 2008 1:01:19 PM(UTC)
Susan T
Several months ago we noticed that the refrigerator side was warm (55-60f). We pulled it out, thoroughly cleaned all coils underneath and behind. Still warm...thinking the fan might be caked with ice, we turned it off for a day, did an even more thorough cleaning and then turned it back on.
It worked great for about 2 mos. but yesterday the fridge was warm again. This time I emptied out the freezer and removed the panel on the back of the freezer. The coils looked fine, and the fan was blowing. There was no ice caked up anywhere.
I put it all back together and turned it on again. 24 hours later, the fridge is still at 60f (freezer is fine). What should our next step be?
Thanks for your time...Susan
libertyappl
#2 Posted : Wednesday, August 20, 2008 7:49:15 PM(UTC)
libertyappl
Is it running all the time?
post your results
Nat
libertyappl
#3 Posted : Wednesday, August 20, 2008 8:08:52 PM(UTC)
libertyappl
After doing some research I'd say that you either have an air diffuser problem part #AP3046080 (on the upper left of the refrigerator should feel air flow thru there when fan in freezer is on if not then that's probably your bad part) or the freezer thermostat isn't working properly, part number AP2984389
Hope that helps
Nat
Susan T
#4 Posted : Tuesday, August 26, 2008 8:46:38 AM(UTC)
Susan T
Hi Nat--
Sorry it took me so long to respond, but I wanted to thank you for your advice. I also have one more question....
Is there a separate thermostat for the refrigerator section or does the freezer have the only one?
My husband propped the air diffuser baffle open and the fridge cooled very quickly so we're thinking the diffuser has its own thermostat that controls the opening of the baffle??
Thanks again....
Susan
libertyappl
#5 Posted : Tuesday, August 26, 2008 9:14:42 AM(UTC)
libertyappl
If you can pull up the parts breakdown your model has an arm that opens the damper door. I will look it back up and let you know more. I looked it up on searspartsdirect, parts are cheaper here though if you need parts.
Nat
Kenmore Elite side by side refrigerator (Refrigerator & Freezer Repair)
by jfortner 6/18/2022 7:38:51 AM(UTC)
Ice MAker kenmore elite side by side dispenser (Refrigerator & Freezer Repair)
by timwilburn 9/15/2013 3:14:07 PM(UTC)
Kenmore Elite side by side compressor not working? (Refrigerator & Freezer Repair)
by stupidfridge 9/22/2010 12:49:10 PM(UTC)
ice maker stopped working - kenmore elite side by side (Refrigerator & Freezer Repair)
by foobydoo 1/26/2010 1:12:14 PM(UTC)
