I need to know how to replace the two inner glass inserts in my oven door. Model #GMC305PDT6. I took the door apart to clean and one of the glass inserts broke. I am not sure if it is #7 or #10 and I don't remember how to put the glass retaining brackets back in.
Originally Posted by: Gene  Hello, #1,4,3,5 and 19 all are still attached together. I did not take them out of the door. If I put glass #7 into part #5 = then secure it in place with part #20(glass retainer) it lays flat. Now, I put in #l0 glass into #l9 heat shield, it doesn't lay flat,,, it is on an angle. then I have another #20 glass retainer to secure to the #10 glass. Is this the correct order to put all these pieces back into the door? and the #20 glass retainers - do they get screwed together in the same direction because I only have 2 screws to put them back in. I can't quite see from the diagram if this is right. Thank you for your help.....
Hello, I am not sure if you got my last message. I need to know how to put the glass back in. One glass lays flat, the second glass in on an angle. Is this right. It can't lay flat if I have to put into the silver heat shield. and I have two glass retainers and I am not sure how to put them back in. Any help would be appreciated. Thank you.
Originally Posted by: Equinunk1225  Hello, #1,4,3,5 and 19 all are still attached together. I did not take them out of the door. If I put glass #7 into part #5 = then secure it in place with part #20(glass retainer) it lays flat. Now, I put in #l0 glass into #l9 heat shield, it doesn't lay flat,,, it is on an angle. then I have another #20 glass retainer to secure to the #10 glass. Is this the correct order to put all these pieces back into the door? and the #20 glass retainers - do they get screwed together in the same direction because I only have 2 screws to put them back in. I can't quite see from the diagram if this is right. Thank you for your help..... No glasses should be on an angle. Besides the diagram I attached the file with the complete instructions. Did you open this file? Gene.
