chzbykr
#1 Posted : Wednesday, August 20, 2008 3:03:56 PM(UTC)
chzbykr
i have kenmore dryer with the more dry-less dry feature thats quit working the dryer drys fine but won't stop when clothes are dry. any help be appreciated
iamigor5@yahoo.com
#2 Posted : Wednesday, August 20, 2008 4:46:32 PM(UTC)
iamigor5@yahoo.com
need complete model number probably needs a thermistor does it turn off on timed dry???
chzbykr
#3 Posted : Thursday, August 21, 2008 5:25:23 AM(UTC)
chzbykr
hi thnx for the reply. the model # inside the door is 86873800 (off to the side has just 68738). serial # is mx5130576. and no it doen't stop in timed dry either.
bronconaut
#4 Posted : Thursday, August 28, 2008 8:27:45 AM(UTC)
bronconaut
I have the same issue with a Kenmore 110 dryer - it dries fine, but won't shut itself off with either timed dry or autosense dry. The timer knob does not move once set.
Thanks!
kmv
#5 Posted : Wednesday, October 1, 2008 5:06:30 PM(UTC)
kmv
I also have the same issue, dryer does not shut off. Any suggestions??
kmv
#6 Posted : Wednesday, October 1, 2008 5:11:17 PM(UTC)
kmv
Model # 86872100 What part do I need?
iamigor5@yahoo.com
#7 Posted : Wednesday, October 1, 2008 5:20:38 PM(UTC)
iamigor5@yahoo.com
i would probably guess it was the buzzer that is wired to the timer, long story short it drives the timer and the time will count down until last 5 mins and hangs. part #ap3094100
bronconaut
#8 Posted : Thursday, October 2, 2008 5:29:30 AM(UTC)
bronconaut
In my case it was the timer. I replaced it and all is well. An easy way to check - BE VERY CAREFUL - is to watch the back of the timer as the dryer runs. On mine, there is a clear inspection cover. The timer motor was not turning at all. With the new timer you can see the timer motor rotating very clearly.
HTH.
