Originally Posted by: kurtmc ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif)
here is the model number ED27PQ
thank you
Kurt,
On the freezer door, at the top hinge, remove the plastic hinge cover,
Under the cover you will find the dispenser wire harness connector.
Separate the connector, check the pins and the plastic connector for, loose wires or pins, look at the plastic housing for a brown discoloration around the pins(arc marks from loose connections).
Check the wires, where they pass through the hinge opening, for broken, bare wires.
At the dispenser, check the ice dispenser paddle, make sure it is not loose, or broken from the dispenser housing, it may look OK, but you need to wiggle and twist the paddle, there'll be some movement(1/8 to 1/4 inch).
When you press in on the dispenser paddle, you should hear the actuator switch, "click", then another click when you release the paddle.
**Of course, you're doing these checks with no power to the refrigerator**
The most common problem with this style unit and your complaint, is a broken paddle mount assembly, or bad actuator switch.
To access the switch and paddle assembly :
Along the bottom edge of the dispenser front panel, you'll find a molded slot on each side of the bottom edge.
Using a flat blade screw driver, and a pad to eliminate damage to the door panel, pry out on the bottom of the panel with the screw driver(approximately 1/4 inch),and lift up on the panel, to disengage the locking tabs, and remove.
The switch mounting plate is attached to the housing with 3 phillips head screws, remove the screws and slide the panel out. you'll then have access to all the components you need to check.
Once you've determined what parts you need, or if the reccomended checks are all OK, drop us a line, we'll be happy to direct you through the other checks at the auger motor or research the parts you need.
Good Luck,
:cool: :cool: :cool:
