5957rdr
#1 Posted : Monday, November 29, 2010 9:36:45 PM(UTC)
5957rdr
washer run fine but is making a bad sqeaking noise the hole time it is running. any info would help thanks
sidfink43
#2 Posted : Wednesday, December 1, 2010 5:11:53 PM(UTC)
sidfink43
That is unusual for these machines, I mean, a little noise is always present with a Whirlpool Direct Drive that you have but it should not be a loud squeak.
Take a look at the Sticky by Richappy at the top of this page, and use the info to take a look at your clutch and brake assembly.
