tonyottea
#1 Posted : Tuesday, November 30, 2010 1:00:47 PM(UTC)
tonyottea
This oven is 30 years plus but has worked well for the last 16.
I have replaced the bake heating element that had a hunk burned through.
The new element and the broil element would only slightly heat. Removed the new element and measured the following from the three leads: Hot lead #1 to ground wire... 125V: Hot lead #2 to ground...0 volts: Hot lead to hot lead: 125V.
I do not have a schmatic. Is there any kind of fuse or breaker in the control panel that will restore the voltage?
Tony Ottea
#2 Posted : Tuesday, November 30, 2010 3:16:08 PM(UTC)
Tony,
You may want to start from verifying 240 VAC to the oven. Measure the voltage at the oven terminal block.
If there is nothing wrong then the problem is a bad oven thermostat or a bad oven selector switch. Without a schematic the only way is to trace the hot lead with 0 volts reading to see where it goes.
Here are the breakdown diagrams and Replacement parts for JENN-AIR 800181 WALLOVEN- STD ELE | AppliancePartsPros.com
tonyottea
#3 Posted : Tuesday, November 30, 2010 5:39:04 PM(UTC)
tonyottea
Tony,
Thank you Gene. I will track the wire since there is 220v to the second oven.
Thanks again
#4 Posted : Tuesday, November 30, 2010 8:28:08 PM(UTC)
