My dryier wont stay on i pust start button and will come on but as soon as i release it it goes off still tumbles and heats up had starter switch checked it is good plzz help what do i do now:confused:
Sounds like a bad motor to me.
Most likely the problem is a bad motor run winding or a bad motor switch. The motor is not repairable and has to be replaced. - The drive motor Part number: AP2107144
