RT37
#1 Posted : Tuesday, November 30, 2010 2:23:45 AM(UTC)
RT37
Hi All,
Our General Electric TBX22ZAZBRWW Refrigerator makes a loud clunking noise from the rear bottom after each cooling cycle. I am a novice. Sorry for the poor detail. My guess would be something has worked its way loose, but I not sure what to do or where to look.
This has gone on for months without incident, but time to resolve, if possible.
The unit works fine, just trying to avoid a costly emergency repair/replace.
Many thanks for your time and any input
RT37
magician59
#2 Posted : Tuesday, November 30, 2010 5:50:17 AM(UTC)
magician59
That will probably be the compressor. When internal springs (suspension) break or wear out, the body of the comressor will start knocking against the outer case. Eventually, it will cause enough damage that it will no longer work.
RT37
#3 Posted : Tuesday, November 30, 2010 7:11:09 AM(UTC)
RT37
Thanks for the quick reply - Is it worth replacing the compressor?
Keeping in mind my novice status :D
magician59
#4 Posted : Tuesday, November 30, 2010 7:23:54 AM(UTC)
magician59
Compressor replacement has become one of those highly debated topics in this industry. It's expensive. You can expect it to cost naywhere between $500 and $1200, depending on your locale.
Also, No matter how careful we are doing the job, they lend themselves to a high prercentages of failure rate. You gotta really love your refrigerator to make this kind of commitment.
RT37
#5 Posted : Tuesday, November 30, 2010 7:52:40 AM(UTC)
RT37
thanks for the wisdom and insight magician59!
have a wonderful day!
RT37
applianceman
#6 Posted : Tuesday, November 30, 2010 8:32:47 AM(UTC)
applianceman
Just a suggestion…
I have known for refrigerator compressors to make this noise for years and not effect performance of the compressor. Mine at home has been doing it for 2 years now and is still running fine. I am not saying that this isn’t damaging something, just that it could last a long time making this noise.
So if you can put up with the noise now and then it may keep running for a long time. I wouldn’t suggest replacing the compressor because of this but it is up to you.
Refrigerator repair guide
