JESIMMONS
#1 Posted : Monday, November 29, 2010 6:20:10 PM(UTC)
JESIMMONS
My Dryer Will Run And Dry Properly Only If It Is Held In The Start Position,i Replaced The Start Switch Already
#2 Posted : Tuesday, November 30, 2010 12:58:46 AM(UTC)
Here is the parts breakdown
Replacement parts for General Electric DS4500EB0WW Electric dryer | AppliancePartsPros.com
The unit has a belt break switch (Item 803 in Section 1) perhaps this is not closing for some reason or it is shot.
Here is a wiring diagram for a typical GE unit. It probably does not match your unit exactly but will give you an idea of how the above switch is wired in.
http://www.applianceaid.com/newimages/ge-newelec-diagram.JPG
When the motor gets close to operating speed the centrifugal switch (M5/M6) closes.
This removes the start motor's winding from the circuit as the motor will overheat if it is left in circuit.
It also provides an alternate/parallel circuit path through the belt switch for the start switch so that you can release the start switch and the unit continues to run.
