2 Pages12>
adamerik
#1 Posted : Wednesday, November 5, 2008 2:34:26 PM(UTC)
adamerik
There was a creaking noise right before it would ignite. Then it stopped igniting. I replaced the igniter and it worked. The next time I tried to turn it on it wouldn't ignite again. It just clicked and the igniter sparked. The bake is the only thing that will not work everything else works great. What do I do?
#2 Posted : Wednesday, November 5, 2008 3:01:32 PM(UTC)
Did you replace the igniter together with the Bake burner?
Did you hear gas coming out when the igniter clicks?
adamerik
#3 Posted : Thursday, November 6, 2008 7:41:06 AM(UTC)
adamerik
No I did not replace burner. No I did not smell or hear the gas.
#4 Posted : Thursday, November 6, 2008 10:39:16 AM(UTC)
1. Remove the rear cover from the control panel. Remove the Red wire from the P24 terminal on the control board and check for 120VAC between the P24 terminal and ground while the control calls for Bake.
If there is no 120VAC then replace the control board.
If there is 120VAC then proceed to step 2.
2. Remove the bottom drawer and locate the gas valve/regulator on the back. Label the three wires connected to the gas valve/regulator and remove them. Check the Bake and Broil solenoids as described in the tech sheets (page 3).
Replace the gas valve/regulator if any of the readings is wrong.
Replace the spark module if there is nothing wrong.
- The part number for the gas valve/regulator is AP3866825
- The part number for the spark module is AP3672576
In order to provide the right part number for the control board I need the color of the touch pad and the last digit (after "Q") in the model number.
msenn
#5 Posted : Thursday, November 25, 2010 6:57:49 PM(UTC)
msenn
gene, do you have the tech sheets available? the link above did not work and i've got one of these ovens doing the same thing.
thank you,
matthew
#6 Posted : Friday, November 26, 2010 3:54:14 PM(UTC)
thank you,
matthew
Unfortunately this tech sheet is no longer available on line. The following are instructions for the troubleshooting:
The middle terminal is Common, the upper terminal is Broil and the bottom terminal is Bake. Check between each solenoid for 216 Ohms resistance (Broil to Common and Bake to Common). If one of the solenoid is defective, neither one will operate and the gas valve/regulator has to be replaced.
msenn
#7 Posted : Friday, November 26, 2010 4:31:20 PM(UTC)
msenn
thank you. the broil solenoid was at about 118 ohms and the bake solenoid wouldn't register anything... so, looks like i'm ordering a new valve. thank you for your help!
#8 Posted : Monday, November 29, 2010 12:28:39 PM(UTC)
msenn
#9 Posted : Sunday, December 5, 2010 4:44:29 PM(UTC)
msenn
it was indeed the gas valve/regulator. i got it installed in my aunts house today and it worked perfectly! i'm going to start taking more free broken appliances from people at work! :)
Teejer1963
#10 Posted : Wednesday, December 22, 2010 12:12:52 PM(UTC)
Teejer1963
my oven makes it to temp but then wont maintain it a couple smacks with a wrench on the gas valve and it started working fine me thinks i have a spider problem
2 Pages12>
