I bought oven 10 years ago and am getting error codes F-2 and F-3. Do you think I should repair oven or replace.? These codes may mean replace ECR and temperature sensor, is that correct? Is that a big job to install? Is life of oven extended for a long time possibly if I repair? Thank you.
Originally Posted by: ewide  I bought oven 10 years ago and am getting error codes F-2 and F-3. Do you think I should repair oven or replace.? These codes may mean replace ECR and temperature sensor, is that correct? Is that a big job to install? Is life of oven extended for a long time possibly if I repair? Thank you. Ewide, The F2, F3, codes as you mentioned, are usually a bad oven temperature sensor(90-95 % of the time). Part number: AP2023670
It's a relatively inexpensive repair, as well as an easy repair,(in most cases you can remove and replace the sensor, without using more than 1 tool and don't have to move the unit at all). No, it's not going to extend the life of your range, but you should be fine for quite a while. Even if you need an ERC, it's still less expensive than a new range. Good Luck, :) :) :)
Joe, Thank you so much. I am taking your advice and bought the part. I appreciate your help. Ellen
Originally Posted by: ewide  Joe, Thank you so much. I am taking your advice and bought the part. I appreciate your help. Ellen Ellen, You're quite welcome, As I said previously, be careful, make sure you turn the power off to the range, when you remove the temp. sensor, be slow and don't "yank" on the wires. Good Luck, :) :) :)
