hthreeq
#1 Posted : Monday, August 18, 2008 5:36:37 AM(UTC)
hthreeq
When cleaning the knob, accidentally I left water got in and was not aware of it. As soon as I placed the knob back and turn the burner on, the connection down below the knob sparked and trip the breaker. I unplugged the power supply to the oven as well as the gas supply, removed the switch and clean off everything real good. I put back everything in order and when plugging the power supply, there is a ticking sound like the switch was not completely close. Is this a problem with the switch? And if so, how do I replace it? Also if I wanted to take the switch out to take it to the store, can it be done without cutting the wire? Thanks, hq
#2 Posted : Monday, August 18, 2008 7:28:49 PM(UTC)
Most likely the ignition switch has to be replaced. The wires are plugged into the switch.
- The part number for the ignition switch is AP4277633
Here are the break down diagrams for the Whirlpool range Model SF370PEWN4
hthreeq
#3 Posted : Tuesday, August 19, 2008 10:03:32 AM(UTC)
hthreeq
Thanks! I will buy the part and have it installed later!
Hung
