My freezer is not cooling. Every few minutes I hear a click (I assume it is the compressor starter relay) and I have verified that the evaporator fan is running. The evaporator is not cool to the touch. The last time I had these symptoms the evaporator fan wasn’t running and the evaporator was chilling nicely. Is there anything other than the compressor (I am assuming its the compressor) that can cause this issue. I am making the assumption that the starter relay is good because I am hearing something click. I am also assuming that the control circuit it working because I assume it is sending the start signal to the relay. Any troubleshooting tips would be appreciated. Thanks
I was not sure how to post a new post on here so I am replying to get posted.However, I have a similar problem.My relay was clicking so I took it off and searced the model number but it does not come up on this site.I have a Kenmore side by Side coldspot.model # 106.53582300 .So how do I get the correct relay
You can call this parts site or crunch into Google the Sears parts site.
Thanks I found the part number by calling a couple of appliance parts houses. Sears only gave me their part number. The lowest price I found was at appliancerepairparts.com.My total with shipping was only 44.00 bucks as opposed to 49.99 before shipping with Sears. Several other sites had the same part on an average of 53.00 before shipping.
