mvan105
#1 Posted : Monday, November 22, 2010 4:06:29 PM(UTC)
mvan105
I'm getting no heat at all from the dryer. I've used the manual and followed the instructions to use white vinegar to clean the sensors inside the dryer. Power works but it blows cold air. I've tested it on timed cycle and made sure I'm using the heated dry and not air fluff. I've cleaned all the vents, condenser, lint filter, etc.
There is a small red button on the high limit thermostat that's connected to the heater, when I opened the back of the unit I was able to push it and it seemed to click slightly. I thought this may have solved the issue but after testing again still no heat. The red button doesn't pop up again.
My next step is to try and replace the very inexpensive fuses in the fuse box and see if that has any change although I doubt it considering the entire front panel is working fine.
I'm guessing the heater AP2805474 needs to be replaced but I'm not 100% sure. Any advice?
Read more: http://forum.appliancepartspros...-heat.html#ixzz163yTnexH
http://forum.appliancepartspros.com
