2 Pages12>
farmerscot
#1 Posted : Saturday, August 16, 2008 5:44:42 PM(UTC)
farmerscot
The timer stuck on my dryer, i checked it out and it was getting power just not doing anything. I ordered a new one ($85.00) and it worked one time, and also quit. it is power is getting to it but it isn't moving. Any ideas? :confused:
libertyappl
#2 Posted : Saturday, August 16, 2008 6:50:36 PM(UTC)
libertyappl
Can you post exactly what it was doing before the new timer and your model number?
Nat
farmerscot
#3 Posted : Sunday, August 17, 2008 7:14:04 AM(UTC)
farmerscot
The model # DLB1550RALAD. The dryer was working fine and then the time just stopped moving. I replaced the timer, it worked one time and the next time it just stayed where you put it. Is there something that would burn out timers?
libertyappl
#4 Posted : Sunday, August 17, 2008 6:17:55 PM(UTC)
libertyappl
Did the dryer stop heating & turning or just the timer?
farmerscot
#5 Posted : Sunday, August 17, 2008 6:40:10 PM(UTC)
farmerscot
Just the timer. it still runs and heats, just wont stop.
libertyappl
#6 Posted : Sunday, August 17, 2008 7:00:13 PM(UTC)
libertyappl
How much voltage is getting to the timer? Have you tried other settings?
#7 Posted : Monday, August 18, 2008 1:59:02 AM(UTC)
Check the timer wiring per. the schematic.
farmerscot
#8 Posted : Monday, August 18, 2008 4:32:56 PM(UTC)
farmerscot
about 123 volts on a digital meter. I have tried all the settings but the timer motor just doesn't seem to be running. It just stays where you turn it. I have talked the local supply house into giving me another one but I am afraid that something will happen to it. I have studied the wiring diagram but just can't explain what could cause it. Maybe I just got a bad one?
libertyappl
#9 Posted : Monday, August 18, 2008 6:19:51 PM(UTC)
libertyappl
It's always possible to get a bad part. Nat
libertyappl
#10 Posted : Monday, August 18, 2008 6:23:41 PM(UTC)
libertyappl
Did you check the resistor & board assembly(#148 on the diagram) or the SUPPORT CIRC BOARD (#42)?
Nat
Guest (10)
2 Pages12>
