poslow
#1 Posted : Sunday, November 21, 2010 4:18:55 PM(UTC)
poslow
My Kenmore Dryer of about 5 years, model 110.C66532500 29" cabinet is not functional.
I noted that the timer is not moving with no heat coming out and the dryer does not shut off.
I have gone on to search the forum.
Could it be the problem of the timer ?
poslow
#2 Posted : Sunday, November 21, 2010 6:35:41 PM(UTC)
poslow
I stripped off the back of the dryer, went through the forum's posting carefully. I took out the Dryer Heating Element and found a break in the coil.
The part number of this Dryer Heater Element is :-
Whirlpool Electric Dryer Heating Element 279838.
I think this could be the problem ???
#3 Posted : Sunday, November 21, 2010 9:10:49 PM(UTC)
Yes that is probably your problem.
In many units when in an auto mode the timer motor gets power through the heating coil when the coil is off.
Therefore a bad (open) heating coil will stop the timer advancing.
Note: In a timed dry mode the timer motor usually gets power directly from the line so it should have advanced in timed dry.
