2 Pages12>
drs
#1 Posted : Saturday, August 16, 2008 11:55:10 AM(UTC)
drs
Gas dryer starts/runs ok AT START... but heating stops after about 5-10min (with tumbler/blower still going). To be clear, sequence is:
- dryer starts/runs AS NORMAL for a minute or so...
- then i can see glow/igniter start...
- gas flame lights & runs as normal for ~5-10min...
> but then stops & does not relight (although I've seen glow/igniter heat up)
- dryer continued tumbling on with cool air.
Other info:
* if allowed to cool down for say 5min, will restart above sequence
* if a quick 1min stop/restart tried, there is no gas re-lighting (although glow/igniter goes on for a few seconds)
* I suspect the sensor (on heater section), yes/no? It measure less than 1ohm accross whether hot OR cold.
* i have not tested/measured other thermostats...
Thx.
DRS
Can see the glow/igniter
libertyappl
#2 Posted : Saturday, August 16, 2008 12:10:50 PM(UTC)
libertyappl
Hi, Check the thermostats for continuity. Unfortuneately the model number posted I can locate anywhere.
Can you please double check that.
Nat
drs
#3 Posted : Saturday, August 16, 2008 12:37:01 PM(UTC)
drs
Ok thanks, I'll check them. Model number is Whirlpool SGDS800HQ0 (think i might have intially typed "5" vs. "S"). Whirlpool gas dryer with Costco/Kirkland badging.
drs
#4 Posted : Saturday, August 16, 2008 1:18:31 PM(UTC)
drs
Found that:
-Sensor continuity good, at ~0 ohms (still);
-Main thermostat, has 4 leads;
> with ~0 ohms between two of them and
> approx. 7k ohms between the 2nd set of leads.
-Backup thermostat at 0 ohms
Whether hot or cold, the resistances above do not seem to change.
Let me know that you think.
Thx.
DRS
libertyappl
#5 Posted : Saturday, August 16, 2008 1:32:02 PM(UTC)
libertyappl
did you check them with wires attached or detached?
drs
#6 Posted : Saturday, August 16, 2008 1:57:50 PM(UTC)
drs
It was a detached measurement...
Add'l. info: Also, when dryer unning, no voltage DROP accross any of the (three) sensors/thermostats... (measures 117vac at each terminal)...
libertyappl
#7 Posted : Saturday, August 16, 2008 2:11:38 PM(UTC)
libertyappl
I'd have to say the regulator is going out.
#8 Posted : Saturday, August 16, 2008 6:45:21 PM(UTC)
DRS,
According to your description, most likely the problem with your dryer is a bad gas valve coils.
- The part number for the kit of coils is AP3094251
Here are the break down diagrams for the Whirlpool dryer Model SGDS800HQ0
drs
#9 Posted : Sunday, August 17, 2008 6:48:12 AM(UTC)
drs
Gene & ibertyappl;
Are you guys talking about the same part; coils / regulator?
According to your description, most likely the problem with your dryer is a bad gas valve coils. ( AP3094251 ). Diagrams for the Whirlpool dryer Model SGDS800HQ0.
Thx.
DRS
libertyappl
#10 Posted : Sunday, August 17, 2008 7:08:16 AM(UTC)
libertyappl
The coils are on top of the regulator. You can see them on the break down of your dryer.
Hope that helps.
Gene was more help than I was. Glad he jumped in!
Nat
2 Pages12>
