pabear
#1 Posted : Saturday, August 16, 2008 11:16:58 AM(UTC)
pabear
Maytag Neptune mah 8700 aw wont drain. Getting nd error message. Have done research on possible problems, but not sure how to get access to pump assembly. please assist. Thanks, PB
libertyappl
#2 Posted : Saturday, August 16, 2008 11:31:28 AM(UTC)
libertyappl
hi,
There is a access panel on the back of the machine to access the pump. Sounds like you have a bad pump or an obstruction.
I have this same model.
Nat
pabear
#3 Posted : Saturday, August 16, 2008 11:41:59 AM(UTC)
pabear
Thanks for quick reply. Is this something a novice can tackle or do you recommend a service tech? About how much should I expect to pay for pump replacement?
libertyappl
#4 Posted : Saturday, August 16, 2008 11:46:01 AM(UTC)
libertyappl
Yes it's actually not overly difficult the part number for a complete pump assembly is AP4044238. But I would check for an obstruction first. You'd be sureprised what can get into a pump. We've pulled class rings, bra underwires, socks, etc.
Hope that helps
Nat
libertyappl
#5 Posted : Saturday, August 16, 2008 11:52:13 AM(UTC)
libertyappl
Here's how simple it is....
Drain Pump Removal
1. Disconnect power supply to unit.
2. Remove Back Cover.
3. Remove clamp and Drain Hose.
4. Remove clamp and Pump Hose.
5. Remove wiring connector.
6. Remove three 13mm bolts securing Drain Pump to
base.
7. Remove screw securing Drain Pump to bracket.
Twist Drain Pump clockwise to remove.
Hope that helps
Nat
Washer wont drain, after motor replacement (Washer Repair)
by rweltz 6/15/2018 4:41:50 AM(UTC)
HELP! Whirlpool washer full - fill light keeps flashing - wont drain (Washer Repair)
by washerproblems017 10/21/2017 3:06:50 PM(UTC)
Whirlpool washer wont drain or spin (Washer Repair)
by nancyelaine 2/15/2017 7:59:14 PM(UTC)
Frigidaire stacked washer wont drain (Washer Repair)
by Davidc67 2/11/2017 2:03:16 PM(UTC)
washer wont drain and trips circuit (Washer Repair)
by cglou 11/29/2016 1:07:14 PM(UTC)
Neptune Wont Drain (Washer Repair)
by dstrakele 1/23/2016 11:35:24 AM(UTC)
Dishwasher wont drain - had new motor (Dishwasher Repair)
by brady5885 10/31/2015 9:51:05 AM(UTC)
Washer Wont Drain At End of Cycle (Washer Repair)
by mvrk28 8/2/2015 3:24:30 PM(UTC)
by rviets 6/24/2015 2:45:24 AM(UTC)
GE washing machine wont drain or spin but agitates (Washer Repair)
by Billybrokege 5/14/2015 2:26:58 PM(UTC)
Roper washer wont drain or spin (Washer Repair)
by tj1217 8/13/2014 6:33:05 AM(UTC)
Whirpool washer agitates but wont drain or spin (Washer Repair)
by kmsimpso 5/10/2014 9:17:09 AM(UTC)
Whirlpool dishwasher wont drain (Dishwasher Repair)
by JayTeeC 3/30/2014 1:53:15 PM(UTC)
washer wont drain or spin, will agitate only on light cycle (Washer Repair)
by maggie_o 10/21/2013 2:09:20 PM(UTC)
ge dishwasher pdw8680n00ss wont drain (Dishwasher Repair)
by Bellebelle 10/3/2013 1:09:14 PM(UTC)
