RPaaren
#1 Posted : Saturday, August 16, 2008 9:08:14 AM(UTC)
RPaaren
Washer spins but doesn't always drain. This happens intermitently regardless of the cycle. Pump is free of foreign objects. Thoughts?
libertyappl
#2 Posted : Saturday, August 16, 2008 9:19:40 AM(UTC)
libertyappl
Hi
check the hose going into the pump from the tub. or may have something between the tubs.
Hope that helps
Nat
RPaaren
#3 Posted : Saturday, August 16, 2008 9:54:24 AM(UTC)
RPaaren
Thanks Nat. Clarifiaction on condition. Wash cycle (Regular, Delicate, Hand Wash) doesn't make a difference, but when the Spin Cycle selection switch is set to SLOW, the water doesn't drain after rinse. Thoughts?
Bob
libertyappl
#4 Posted : Saturday, August 16, 2008 9:58:35 AM(UTC)
libertyappl
Bob,
How long does it take to drain when it does drain?
RPaaren
#5 Posted : Saturday, August 16, 2008 10:23:00 AM(UTC)
RPaaren
It doesn't. I have to change the washer's Wash/Spin setting back to "Regular" which is Nrmal/Fast. Any wash spin setting using a /Slow combination does not discharge the water. Sound confusing?
Bob
libertyappl
#6 Posted : Saturday, August 16, 2008 10:36:26 AM(UTC)
libertyappl
Bob,
It sounds like a motor problem. That is a 2 speed motor and one side maybe out.
Nat
RPaaren
#7 Posted : Saturday, August 16, 2008 10:51:10 AM(UTC)
RPaaren
Thanks for your HELP!
maytag washer doesn't always drain (Washer Repair)
by cbyrd3 6/2/2010 7:54:49 PM(UTC)
