Washer spins but doesn't always drain. This happens intermitently regardless of the cycle. Pump is free of foreign objects. Thoughts?
Hi check the hose going into the pump from the tub. or may have something between the tubs. Hope that helps Nat
Thanks Nat. Clarifiaction on condition. Wash cycle (Regular, Delicate, Hand Wash) doesn't make a difference, but when the Spin Cycle selection switch is set to SLOW, the water doesn't drain after rinse. Thoughts?
Bob
Bob, How long does it take to drain when it does drain?
It doesn't. I have to change the washer's Wash/Spin setting back to "Regular" which is Nrmal/Fast. Any wash spin setting using a /Slow combination does not discharge the water. Sound confusing?
Bob
Bob, It sounds like a motor problem. That is a 2 speed motor and one side maybe out. Nat
