Frankie2201
#1 Posted : Thursday, November 18, 2010 2:18:39 PM(UTC)
Frankie2201
Motor does not work just hums. Is the motor worth replacing on this old of a machine. Cost of new motor is $114.18
ThatGuy
#2 Posted : Friday, November 19, 2010 3:35:11 PM(UTC)
ThatGuy
Groups: Expert
United States
My personal opinion is no. Its too old to repair. If you had a used motor laying around, sure. But that much money and time on 25 year old washer is too much.
Frankie2201
#3 Posted : Saturday, November 20, 2010 12:21:06 PM(UTC)
Frankie2201
thank your for your opinion. time is not an issue for me. have you heard of transmissions having problems on these machines?
ThatGuy
#4 Posted : Saturday, November 20, 2010 3:39:03 PM(UTC)
ThatGuy
Groups: Expert
United States
I've been working on these for a little over 20 years now and I've seen just about every kind of failure that you can imagine and some you can't.
On a machine this old, 25 to 30 years plus, its not unusual to see the center bearings go bad, the main seals leak, the tub rust out in multiple places. The bolts that hold the tub rust off, the top of the tub rust away, the center post of the tub rust in two, the clutch wear down to the metal, the pulleys wear out, motor bearing failures, transmission chewing up its gears or spewing out its oil, the timer contacts burnt away, wires break in the harness or burn up, pressure switches that won't shut off or fill, and numerous other things that happen when a machine holds water and is around 30 years old.
I'm just saying that if you have to buy a new motor for one of these, that money might be better spent on a nice used machine or a new one. Its totally up to you what you do with your money.
If you were one of my customers. I would advise you against fixing it. I'm not trying to pick on you, I'm just trying to tell you the truth.
Whirlpool WRF535SWHZ07 Won't Program Control Board (Refrigerator & Freezer Repair)
by Guest 7/5/2024 1:43:28 AM(UTC)
WRF989SDAM03 Whirlpool fridge making ice very slowly (Refrigerator & Freezer Repair)
by BlueWRXPride 6/20/2024 5:24:45 PM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool fridge WRF560SFYM02 (Refrigerator & Freezer Repair)
by Guest 6/15/2024 5:02:08 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Whirlpool cont. clean stove SF330 PERN6 (Oven Repair (including Ranges and Cooktops))
by bruce.kolozy@att.net 6/10/2024 2:55:08 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
Whirlpool wtw500dw1 won't fill (Washer Repair)
by Guest 6/9/2024 4:14:40 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool LA5700XTN0 won't agitate (Washer Repair)
by Kyou 6/2/2024 5:13:20 PM(UTC)
Whirlpool Flame Cuts off After 5-10 seconds (Dryer Repair)
by Guest 6/1/2024 8:00:29 AM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
Whirlpool Fridge odor (Refrigerator & Freezer Repair)
by Guest 5/14/2024 4:46:42 AM(UTC)
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
