DaveBT
#1 Posted : Tuesday, August 17, 2010 10:48:34 AM(UTC)
DaveBT
Replaced my overload/relay switch with part number 12002794 on my Maytag MSD2732GRS. It worked for about 8 days then it went out again. Same problem as before....buzzing and then a click.. Should I re-order the part and try it again? Or am I destined to have the same problem occur? Do I need to replace something else? Thanks for such speedy responses from all you experts..:)
DaveBT
#2 Posted : Wednesday, November 17, 2010 9:18:02 PM(UTC)
DaveBT
3 months later.....100+ views and no replies.....WOW this forum is full of experts!!!
#3 Posted : Thursday, November 18, 2010 3:02:34 AM(UTC)
The start device in this kit, the black,square thing is very reliable, have never seen one fail. If you have a meter, it should measure 5 to 10 ohms at room temperature.
If ok, and you wired in the run capacitor (if it had one), you now probably have a damaged start winding in the compressor. This probably got damaged by a power surge.
In the future, best to put a 1000 joule surge protector in the fridg wall outlet.
