Originally Posted by: PCGreg
Joe,
Sorry, was out of town for a couple days. I really appreciate the advice. But, I'm still trying to understand how a pressure fluctuation in the water line could cause an obvious electrical failure in the ice maker solenoid. I also know we have pretty low water pressure but I do not understand how a solenoid valve could fail because of that. A solenoid valve is a pretty simple device, a mechanical plunger actuated by an electrical coil. Please help me better understand before I start buying parts.
PC
PC,
You're sort of correct about the way, and process a fill valve solenoid operates,
What you have forgotten is,
You need to maintain a constant minimum pressure on both sides of the diaphram inside the valve(25 psi minimum with a filter system is a good rule of thumb).
Most RO systems don't maintain a constant minimum psi, and the reversal process, brings it even lower, and sometimes and in some cases, you actually achieve a vaccuum.
The lower the water pressure, the less water flow, the less water flow/pressure, the longer the solenoid windings are energized, causing a pre mature failure of the coil and a burnt out solenoid.
I believe I mentioned, in most cases your ice maker solenoid usually fails before the dispenser valve, because , it cycles approximately once every hour until the cubes trip the bale arm and shuts the unit off, where as your dispenser, cycles, on an as used basis or inconsistantly.
If you remove the water filter, your operating pressure can be as low as 20 psi and operate satisfactorily for a while.
I don't know where you're located, but where I was located and working before I came here, several of the RO system companies offerred a "check valve" or a regulator on the system to maintain a constant pressure to the refrigerator fill valve.
Here's an excerpt from a service manual, I hope may help:
Water pressure is extremely
low.
• Cut-off and cut-on pressures
are too low (well systems only).
• Reverse osmosis system is in
regenerative phase. • Have someone turn up the cut-off and cut-on pressure on
the water pump system (well systems only).
It is normal for a reverse osmosis system to be below 20
psi during the regenerative phase.
I hope this post helped explain the situation better.
