I have a Maytag glass cook top (MN CSG7000CAB)and I am looking to swap out my rear top switch burner but I do not know how to get access to it. Are there any screws to remove to undo the glass top. Thanks in advance:)
Look in the cabinet it's installed in to see if it is anchored or clipped in. Do what you have to to remove the fasteners, if there are any. The unit will then come up out of the hole. The screws that hold the top to the body will then be visible. Be sure you unplug it and turn off the gas, before you remove the unit; and lay out towels or something to protect counter tops.
