peterg1
#1 Posted : Tuesday, May 11, 2010 3:48:34 PM(UTC)
peterg1
I think Kenmore makes this, but I heard that it also might be a Whirlpool.
Load will agitate but not spin or drain.....any help you can give me?
#2 Posted : Tuesday, May 11, 2010 6:02:43 PM(UTC)
Kenmore makes nothing. This washer made by Whirlpool for Sears and sold under Kenmore name.
You may want to check the lid switch first.
- The lid switch Part number: AP3100003
peterg1
#3 Posted : Tuesday, May 11, 2010 6:09:50 PM(UTC)
peterg1
Gene, if the lid is down the whole time and the washer will agitate but just not spin or drain....does the lid switch control that?
#4 Posted : Tuesday, May 11, 2010 8:50:30 PM(UTC)
Does the motor run when it should spin?
Does it make any noise?
peterg1
#5 Posted : Thursday, May 13, 2010 3:40:59 PM(UTC)
peterg1
no, the motor does not run, nor is there any noise....everything stops
#6 Posted : Thursday, May 13, 2010 8:11:23 PM(UTC)
Now you need an Ohmmeter. Remove the washer cabinet. Check the motor, motor wire harness and the timer. Here is the Wiring diagram.
File Attachment(s):
How to remove the washer cabinet.doc (25kb) downloaded 27 time(s).
quincy48
#7 Posted : Saturday, November 13, 2010 6:05:42 AM(UTC)
quincy48
Gene,
Any chance I can get a copy of that Wiring diagram? I am having the same problem with the Galaxy machine. Same model same problem, not draining. So is it the lid switch or the pump?
#8 Posted : Monday, November 15, 2010 4:14:26 PM(UTC)
Quincy,
A faulty lid switch is very common problem while a bad motor is very rare. You do not need any diagrams to check the lid switch. Just close the lid and if the switch would not click - this is the culprit.
In case of any further questions post the complete model number of the washer.
bigbaby26
#9 Posted : Wednesday, March 16, 2011 10:04:41 AM(UTC)
bigbaby26
how do you get it to spin it will wash but stop when its time to spin
#10 Posted : Wednesday, March 16, 2011 12:53:01 PM(UTC)
If the washer does nothing and it is silent, most likely the problem is a bad lid switch.
