BrassMonkey
#1 Posted : Thursday, June 17, 2010 12:35:31 AM(UTC)
BrassMonkey
I read Gene's post recently and easily diagnosed and fixed the thermal fuse on my dryer (Thanks Gene!). But on one of his posting he said if the thermal fuse is blown, you should also replace the cycling thermostat but in another post he said replace the high limit thermostat if the thermal fuse is blown. So which one do I replace? The cycling thermostat or/or the high limit thermostat?
Also could someone tell me why would you need to replace it? Does the
thermal fuse get blown because one of the thermostat sets is bad and keeps blowing it out?
http://forum.appliancepartspros.com/12764-post2.html
http://forum.appliancepartspros.com/63232-post7.html
airmike
#2 Posted : Monday, November 15, 2010 5:23:12 PM(UTC)
airmike
Bump. I would like to know the answer to this question too!
