JWSTEXAS
#1 Posted : Thursday, August 14, 2008 1:36:41 PM(UTC)
JWSTEXAS
The washer will fill and it will spin, and empty, but it will not agitate. Instead it makes a loud humming noise from the motor
#2 Posted : Thursday, August 14, 2008 2:38:15 PM(UTC)
Pull the outer panel, remove pump and motor and turn the tranny coupler counterclockwise. Check to see if the agitator agitates, if not you have a bad tranny.
JWSTEXAS
#3 Posted : Tuesday, August 19, 2008 2:49:52 PM(UTC)
JWSTEXAS
Ok, i checked the tranny, like you said, and now it appears to be working agian. Why would it not work, and then just start working agian?
#4 Posted : Wednesday, August 20, 2008 1:10:35 AM(UTC)
A piece of the coupler may have jammed the motor, just check, or the pump may have jammed temporarily.
110.24622300 direct drive washer wont agitate or spin motor hums (Washer Repair)
by Guest 10/10/2021 7:32:00 PM(UTC)
washer wont agitate or spin (Dishwasher Repair)
by steve2016 4/21/2016 8:12:47 AM(UTC)
washer wont agitate (Washer Repair)
by jgraves1 1/23/2016 12:26:39 PM(UTC)
Maytag Washer Wont Agitate When Clothes Is Addded (Washer Repair)
by dyedra 10/13/2015 12:40:16 PM(UTC)
Whirlpool washer wont agitate (Washer Repair)
by SPOONMAN1 3/16/2015 6:02:53 AM(UTC)
my washer wont agitate or spin ULTIMATE CARE ll (Washer Repair)
by ballprez6 12/26/2014 11:12:12 AM(UTC)
GE Profile washer wont agitate or spin, motor will hum (Washer Repair)
by copperman 8/12/2014 4:20:30 PM(UTC)
washer wont agitate or spin (Washer Repair)
Belarus bjsmith7 3/9/2014 7:19:34 PM(UTC)
washer wont agitate, drain, spin (Washer Repair)
by dbaker@ctgastro.com 2/18/2014 10:54:15 AM(UTC)
Ge Washer Wont Agitate (Washer Repair)
Belarus Hexster 4/26/2013 12:49:50 PM(UTC)
Costo washer wont agitate, drain or spin (Washer Repair)
by azalbino 4/17/2013 6:40:12 AM(UTC)
Maytag Atlantis MAV9600EWW washer wont agitate. (Washer Repair)
by Laynechain 1/7/2013 1:56:45 PM(UTC)
whirlpool washer wont agitate makes noise (Washer Repair)
by howard48 8/11/2012 9:31:27 AM(UTC)
roper washer wont agitate or spin!!!! (Washer Repair)
by mrbreezio 4/28/2012 12:24:29 AM(UTC)
maytag washer wont agitate (Washer Repair)
by sleeverbar6 1/16/2012 9:10:09 AM(UTC)
